1 - 12 of 12 Posts
gday
what are the 2 wires that come out from under the ip timing cover blue and green are these for the tacho??? is it suppose to plug into the plug next to the edic motor plug???
I don't believe they do. Could be wrong, don't have the wagon at work so I can't have a look, but from memory a bit of reading around the web showed that a fair few of the pre-turbo motors didn't have the tachos.
tacho sender
You can either remove the sender and replace with a blanking plate (as found in sd33 non-turbo) or just cut the wires off if you have no intention of installing a tach. If you are running 24v you may have a replacement motor (check eng. no.) or someone at some stage has started to put the tach in.I am running 24v at present and have a 12v tacho dash which i fitted no probs as the main circuitry is wired through the 12v accessory relay.This has worked fine,as an example; roundabout 100k's registers 3k on the tach,in 5th gear.This is running m.q diff ratio of 4.625. Hope this helps,Mark.
1 - 12 of 12 Posts
