1 - 5 of 5 Posts
Hi guys my 2001 3L stopped the other day and i found out that it was the injector pump that had failed. I have found another pump but was wondering if anyone has the procedure on how to time the pump and remove and install one. I have tried to get a manual but all the shops have sold out and best i can get is 2 weeks away.
Can anyone help please.
Go Hard or Go Home
Mate unless your very competent with the 3ltr IP, I'd strongly recommend that you take it to an expert 3ltr Patrol mechanic, someone like Berrima diesel for example. The 3ltrs are so sensitive to grenading & if the Ip is not set/timed correctly, you may have some serious issues.
Where are you located mate? maybe someone can give you a copy of the Patrol manual if your colse to them?
1 - 5 of 5 Posts
