Hello folks, I have just secured a complete 2002 TD42T motor for my conversion into a 2000 GU wagon with a dead ZD30 in it. While the motor is out of the vehicle, now is the time to do any work to it before install. I will be upgrading the turbo, any suggestions please, and the fuel system should be upgraded as well. What sized injectors and pump size would I need to
Keep up with 18 to 22lbs of boost and hopefully around the 170kw at the rims. Have a 3 inch dump and exhaust plus a water to air intercooler for it as well. The main question is size of fuel system , type of turbo to give very strong mid range . The vehicle will be used as a comp truck plus extended tourer. I guess I should add 4.3 diff gears 35 inch rubber. Many thanks I look forward to any useful input.
Cheers.
Cheers.
