1 - 5 of 5 Posts
Hello All, I am new to the forum and have a problem with my Patrol and am hoping someone on the forum will be able to help out with advice to solve it. I purchased my Patrol new in 2003 and have been very happy with it for over 200,000kms. Over this time I have had the glow plugs replaced, the intercooler and the upper and lower hoses and fan belt. All of which I was happy to have done. Over the last 6 months and whilst towing a caravan the Patrol has been losing power when negotiating hills (slight of otherwise). It has done this on several occasions (not all). The loss of power is gradual going from a speed of about 80-90kph down to the low 40's notwithstanding that I have the accelerator fully depressed. If I release the accelerator and reapply it the revs pick up for a very short period before losing power again. I have been unable to get the Patrol to replicate the symptoms when taking it to a dealer (twice) (even going for a drive with a tech with the van on and going up some hills). They say without experiencing the issue they cannot properly diagnose the problem. In trying to seek an answer myself I have come across this forum. I noted that one subscriber "Benton" in 2009 had a a similar problem and advice was given to him and this related to carbon deposits in the turbo. I was wondering if Benton is still out there and had the issue resolved successfully. I would very much like to hear the outcome and any other advice to assist in this issue. Thanks, DustyM.
I have seen carbon deposits in the VNT vanes of a turbo but not in a patrol GT 2052 turbo. What this does is stop the vanes from opening as they should, this can be checked by a few methods, the one I like is to connect a bit of tubing to the VNT diaphragm and suck like crazy, you should be able to make the VNT arm rise to the top of the stroke with a little effort (it takes around 13"Hg to make arm rise, you should be able to get 18-20"Hg by mouth). If it doesn't rise then vanes could be jamming from carbon deposits, but as said I've not seen it on a Patrol turbo.
Interesting comment about releasing the accelerator and it comes good until it happens again, this really sounds like it could be a Limp issue, has your MAF been checked?
Thanks for that geeyouytoo, I will bring it to the notice of the tech (patrol currently in getting looked at - again!!). Anything to find out what the problem is .. very frustrating.
DustyM
1. change the fuel filter.
2. Check fuel pipe flow.
3. Fill the tank to the top.
4. put a clear hose behind the filter to see if there is an air bubble.
1 - 5 of 5 Posts
