1 - 5 of 5 Posts
Hey All,
Just a brain thought while driving in the 43 degree temps today in Sydney.
My new GU has the rear air con unit in the left hand rear panel. I'm guessing this compressor is electric run as I doubt it is engine run from the front.
IF it is a electric run could this be rewired to actually run while the engine is turned off ?
Idea's people
Thanks
Steve
The Googlest, Apparently!
Hey All,
Idea's people
Thanks
Steve
Dont see why not if it is electric, could be a serious power drain with out the engine running though. However, if it is electric I am thinking cold air for the intercooler. How big is it, could it fit an engine bay?? Just a thought.....
There will be a electric blower fan in there to push the air through the rear vents but the actually cooling of the air is carried out by the engine driven airconditioner circulating refrigerant through a rear mounted avaporator so with the engine off you will only get ambient temp air out of the rear vents (the same as the front)
If you look underneath the vehicle you should be able to see a small diameter high pressure pipe & a large diameter suction pipe that carries the refrigerant to the rear airconditioner evaporator
Toyota Prius hybrid vehicles have a electric powered compressor so that the airconditioner will continue to cool when the petrol engine shuts down when stopping the vehicles at lights,etc
Regards Don
x2, by the time a bit of hybrid becomes cheap enough you wont be able to run internal combustion engines. bang goes refridgerated air for the intercooler idea....... though i have thought of routing the windshield vent to the intercooler haha.
1 - 5 of 5 Posts
