1 - 10 of 10 Posts
Hey guys was just wondering wear to find the 24v converter i heard its in the LH A pillar but the only thing i can find there is my automatic computer.
Safari Hoarder
What's you year, trim level and is it LWB or SWB?
Take your jack out, remove the jack support and run your hand up the rear left wheel well. I'll bet it's there.
Why do you want to find it?
It's a swb and my 12 volt accesories speedo temp and oil pressure gauges are turning of an I have to open an close passenger door to get it to turn back on thinking might have a loose wire.
Safari Hoarder
The converter will either be above your auto computer or in the left rear wheel well. If in the left wheel well you need to take the jack and jack support out (for a LWB) and the trim covering the converter. Converter will exit where jack support was. Again this is for a LWB.
Previously known as twodiffs
1991 GQ Safari.
Also check the left front passenger foot side panel...they've been known to hide them there as well.
I found it thanx guys was hiding next to the jack though couldnt find a fault with it, but now i know where to start tracing wirings from looking for a short.
1 - 10 of 10 Posts
