1 - 2 of 2 Posts
Just wondering if anyone has done a 25mm body lift and what is involved? Is it the same as doing a 50mm body lift?
I have a 30mm body lift I made and you don't have the gear stick issues of a 50mm. On my old Patrol I didn't even have to loosen the bolts around the gearstick but on my later one I had to slightly pull the boot down. As with the raidiator shroud on the petrols you only have to trim a small amount off the bottom with a sharp knife, on the diesel mine had the two piece shroud and the bottom piece was already missing when i bought it. 25/30mm body lift doesn't look anywhere near as bad if you deside not to lift the front and rear bars.
For the effort tho why not just fit 30mm coil spacers? Just another option but alot cheaper unless you can make the blocks youself.
1 - 2 of 2 Posts
