1 - 5 of 5 Posts
Hi just wondering if anyone has modified their zd30 engine mounts to fit a 4.2 is it possible? if so can you give me some info on how you did it or even better some photos , ps iv tried cutting the 3.0 mounts off the chassis rails and only owning a 4 inch grinder it's basically impossible to get the grinder in there to do the job and I have no access to a plasma cutter so I'd prefer to modify them cheers
i cut my zd30 mounts out on sunday with a 4 inch i cut across the top and sides then folded them down and sliced them off, then got underneath and cut then ground the welds off
Bush and Beach-Bum
^^x2
Not hard at all.
If worst comes to worst, use a coarse flap or grinding disc and grind them down till they're gone. Don't bother about modifying them, angles and positioning is out heaps.
Do it properly, do it once ;)
1 - 5 of 5 Posts
