1 - 7 of 7 Posts
nissan patrol gu
Does anyone have this set up?
Will 4in Tough Dog adjustable shocks fit under a 2002 GU 4.2TD Patrol with a 3in shocky lift??
If not why not?
I have been told The 4” shocks would be too long in the body and you would probably crunch them on compression.
Is this the case or does this setup actually work.
If you run this set up please tell me how it works???
Thanks
Richard
If not why not?
Thanks
Richard
If you use the right combination of coils & shocks this will work. :D
I regularly supply 3" coils & 4" shocks on patrol members rigs & have had no problems :D
I have lovells 3" springs with 4" tough dog shocks... Combo works very well... The passenger side needs to be checked after being on a hoist but on full articulation the spring doesn't come out... If your worried about it coming out then put half inch spring packers to keep it in place...
That's my 2cents...
nissan patrol gu
That's my 2cents...
I didn't think about them coming out. I have 2in spings with a 1in coil spacer, do you think this would be bad???
nissan patrol gu
Ok cool, sounds like I might be in business then.
Thanks again for the reply. I have added your store to my favourites.
I purchaced this set-up of zordo with longer rear arms and drop boxes... Flexes and rides great!!
I personally would run with 3" springs and I will get drop out cones if the coil spacers don't fix the fallout that only happens on a hoist and not at full articulation( it's only just on a hoist when getting serviced)... Got others things that are more important at this stage, but it will be done...
Spings on mine are medium and I don't have any draws or fridge installed...
1 - 7 of 7 Posts
