We are in the middle of a conversion the u/s 3ltr is out and the 4.2 is in . We have a issue with the distance from the firewall to the back of the tappet cover now about 10mm , we have removed the g/box spacer was told this had to be done CAN ANY ONE TELL ME can I use the 3.0ltr bellhousing or do I need a 4.2 bellhousing
you need a td42 gearbox crossmember either gq or gu both are the same,
if you use the zd30 bellhousing you will need to drill and tap a extra hole for the starter motor
3l housing with adaptor plate
You need a td42 gearbox cross member. Although I have fitted 2 NA td42s with the zd30 xmember no problem. I have also seen highmount turbo td42s fitted with zd30 xmember but the custom dump pipe required is millimeters away from the firewall
ok
thanks guys we will change the g/box cross member over asap we have a full truck that's a stat right off
