1 - 3 of 3 Posts
Hi all just wondering if the 4.8 alt is rated higher than the td one and or if it can be used a a replacement or secondary alt
Cheers Jono
No vac pump on the back of the 4.8 alt, but i believe it does fit. I think you will also find the pully is slightly smaller (74mm from memory), which is a good thing for a TD in my mind as it spins faster at lower revs.
1 - 3 of 3 Posts
