1 - 15 of 15 Posts
Hi does anyone have the wiring diagram for a lp gas1 vapor injection system for a 4.8 patrol, removing system and not alot of plug and play, I think the injector wires were cut and joined. Just like to know where all the wires go before I start pulling stuff out. Thanks All
GHMBC #3
nissan patrol gq lwb,3"lift.
can't help you with the wiring diadram but would be interested in seeing complete setup when its off and making an offer if it's for sale
Yes it will be for sale the system was fitted in '07 so tank may may be in date.
nissan/patrol
Be aware gasburner that for boosted engines the vapour system will require two injectors per cylinder to cope with demand.
GHMBC #3
thanks for that info simmo.am interested to have a play with vapor inj and turbo on another project
nissan/patrol
Go the whole hog and try liquid injection?
Justin
I've looked into this and there doesn't seem to be any DIY systems out there yet. Also I am unsure of the compatibility of an aftermarket ecu to run the show. Most of the systems out from JTG cater for certain cars with proprietary ecu's and equipment with installation only to be carried out by approved fitters. No customs installs in older engines yet.
So far from what I've seen when installed to dual fuel xr6t it gained 15rwkw without any tuning or timing adjustment. Gains have said to be upwards of 30-40rwkw after tuning on the same boost level. Imagine what you can do when the boost is bumped up!
I'm going to wait till there are some examples out there already before I dive into it.
After some quick research I found a company in italy that sells kits and parts for the systems. Things are looking up.
http://www.roushcleantech.com/content/fuel-system-overview
GHMBC #3
Justin
would be good to do with a xr6/8t but probably a giant headache with a tb42 lol. the tb42 is going well with the m90 and blos.instant boost on throttle, running in vac on de acceleration, on zero when cruising :)
Just an FYI.
Back in the early 90's guys were modifying petrol injectors and put liquid gas into them.
Although maybe not ideal it does work.
Justin
Gas tank already pressurised so no need for any extra pumps.
Latent heat of vaporisation was the key to how well liquid injection works.
Justin
Justin
The latest LI systems are using the petrol injectors, but they have a in tank variable high pressure pump. standard tank pressure is no where near enough, and injection pressure is dependent on a lot of variables like butane/propane mix ratio, ambient and engine temp, ect.
Much more sophisticated now but I'm talking over 20 years ago when people were experimenting.
Gas wants to be a vapour so the injectors were a crude but effective means of getting liquid lpg to the engine that then vaporised much faster and easier then petrol.
Justin
1 - 15 of 15 Posts
