I was wondering if anyone has had some experience with an erratic idle to the the point of stalling at times only on cold starts.After 20 secs or so it is back to normal and and no probs till next cold start.cheers..
Yes possible with specfic sized resistor to temp corralation. Would run like crap once warmed up tho.It can be done. Look at wire diagram its a sensor or post it here and i show you how.
I look at the power valve actuator valve.
