I was wondering if anyone has had some experience with an erratic idle to the the point of stalling at times only on cold starts.After 20 secs or so it is back to normal and and no probs till next cold start.cheers..
Put the pipe away mate, cause it aint doing you much goodI think you're on the money there Heliflyer, the 4.8 is tuned to run on 91ron in Oz. Run any higher than that and you're effectively over fuelling.
hi did you solve this problem pls !tomIm on LPG and have the same drama i.e cold start rough idle, turn off and back on smooth again. only first start up in the morning or if it has sat all day at work for instance. Its a 2002 gu 2 4.8. auto.
Mate I want to try all the learning procedures on ya truck to see if thats the issue.Mine just takes quite a few turns to start when cold, occasionally it runs rough when it starts and practically stalls, so I turn it off restart and all good, seems to have started since I fixed my starter motor 2 yrs ago, on Gas tho as far as tuning, I've got a injected system which hasn't been touched in 2 yrs, due for a filter change and check but otherwise runs 100%![]()
Ha ha tried that mate and even brand new battery, just takes a few turns in the morning to start, I got no 2nd battery either lolI can't believe you Muppets are still playing around with this, charge your battery with a decent 3 stage charger, take it off charge in the morning and start. I guarantee you it will start fine.
Then work out why your battery is not charged. i.e. rooted, or Redarc or similar device draining voltage overnight.
Mate just waiting for you to drop by one afo, even got plenty of beer here for you lol,Mate I want to try all the learning procedures on ya truck to see if thats the issue.
After doing to mine ive relised how important the throttle valve closed position,idle air volume learning and accelarator pedal release position learning procedures to the ECU.
Just gone back through this thread and no one has performed this.
You have no idea on what different RON does do you:idiot: , you will NOT over fuel a ULP, ECU controlled car running a 98 instead of 91, and if you think Gas is tuned the same as petrol but a higher octane rating:doh:snip.
