1 - 3 of 3 Posts
Hi everyone, I have a 2014 Nissan patrol. When I'm breaking coming to a stop, the selector, I believe, thinks the car is losing traction so it starts switching between 4L and 4H (see pics attached) Sometimes I hear plastic gears grinding too until I slow right down.
Any thoughts on what this could be? Actuator?
'14 Y61 ZD30 CRD M/T ST
You should never attempt to switch between 4H and 4L while the vehicle is not stationary and the grinding noise you are hearing could cause serious damage to the transfer case.
There is something seriously wrong going on with your car as it would never attempt to switch between 4H and 4L on its own and this behaviour has nothing to do with losing traction. You must have a 4L selector issue and I’d think you need to have it looked at urgently, especially if it’s grinding.
TH
Thank you AndrieK... I have scheduled for a checkup later in this week. The grinding only happens every once in a while but the switching is happening more and more often now.
1 - 3 of 3 Posts
