81 - 100 of 156 Posts
06 Td42ti coil cab chassis
Discussion Starter · #81 ·
best bit is you get 2 for $14 just in case you mess one up;).
Discussion Starter · #82 ·
Just ordered a set of maxilamp 3's..
Will post pics when fitted..
Has anyone else fitted maxilamp 3's???
Do you need to fit in line resistors?
They are still just LED's without any built in control so yes you still need either a resistor or change the flasher unit but if you retain conventional bulbs in the front indicators you usually get away without having to do it. If you change both ends you will have to address it.
Reactions: 45/70
Discussion Starter · #84 ·
Thanks fester.
Discussion Starter · #85 ·
Just ordered an aluminium canopy for ute today..
May take a while to build but will post some pics when fitted.
Discussion Starter · #87 ·
As you can see ive been busy with a few mod's..
Canopy was built by Kylin campers and big mouth scoop came from Mr Bodykits (ebay)..drawers are 900mm Kings and the fridge slide come from MSA and table from Clearview.
I originally wanted to fit an MSA drop slide but was unable to because the mounting position wouldnt allow it to open without hitting ute so I Purchased an ironman glow in the dark (I sholt you not) step to make fridge access easy..
The spare wheel holder also come from Kylin and is adjustable to suit all wheel and tyre combinations.
Next will be an awning when I can decide what breed to get.
Reactions: warthog
2003 GU PATROL
Very nice!
Sent from my Pixel 3 using Tapatalk
Reactions: 45/70
Discussion Starter · #91 ·
Carlton dry mate..Whars a tooheys??
Reactions: Haggie
Discussion Starter · #93 ·
troy waters his tooheys blue cans down with sprite..
Discussion Starter · #94 ·
Fester was right..
No probs when changing tail lights to led but when I put led's in bull bar I had to fit resistors..Got some Jw Speaker ones from Autobahn $15 from memory.
Reactions: Marko_SJ
Discussion Starter · #97 ·
Discussion Starter · #99 ·
No Karen.
