Front freewheeling hubs not engaged.Hi all!
I have a Patrol Mk 1986 SD33T.
When I put it in 4H or 4L its still only in 2wd.
I can see both propshafts moving but it will only drive the rear wheels.
This is actually real good info for a noob like me. Many thanks.You can not engage auto hubs manually.
when you unbolt the auto hubs you can check if the axles are driven.
put transfer in 4H and pull handbrake,have someone twist one side of the CV axle and check if the opposite side is turning. if not there is an axle damaged or your spidergears are broken.
