This is timely..........
I have a 'Dec '99 Series 1 GU TD42T. It's done 160,000km. Some towing, but nothing too heavy. I bought it new, and it's had a very easy life.
I changed all the driveline oils today. The oil that came out of both diffs and the transfer case was like new. The oil from the gearbox was heavily discoloured, but the magnet on the drain plug was clean and chip-free. Is this discolouration normal? I last changed it at 120,000km, but don't remember it being discoloured like this.
I've lately been getting some driveline vibration at low speed in 5th gear only, otherwise all OK. I suspect it might be time for the 5th gear upgrade that I've read about. Am I on the right tram?
If I am, I may as well add a new clutch and reduction gears while it's being done. I reckon 43% could be the go.........any opinions or experiences with the different reduction ratios?? I don't do any hard core stuff, but sometimes lower would be better with the camper hooked on the back.
Cheers,
Geoff
New oil on the left................same oil, drained at 160,000km (after 40,000km), on the right
