1 - 2 of 2 Posts
hey folks!
i have purchased myself a set of IRONMAN 6" suspension lift kit. The kit includes
all shocks and springs.
extended brake lines
5 degree castor correction plates
2 x panard rods
sway bar extensions
6" IRONMAN LIFT KIT SUIT PATROL GQ GU SERIES 1 & 2 (eBay item 200533980059 end time 01-Nov-10 00:00:04 AEDST) : Cars, Bikes, Boats
thats the kit i purchased.
What else is required to install the lift kit ?
I know i am going to need to get DROP BOX'S to drop the radius arms.
Will i need any spacers for the gearbox or diff ?
What else ir required oor needs to be done in order for this lift kit to be installed ?
i also know that i need bump stops.
HAS anyone done this modification before and or can show pics ?
i will be using the 6" suspension lift with a 2" chassis lift.
cheers folks!
If you have 5" castor plates, you don't need the drop boxes I wouldn't think. You generally use one or the other.
1 - 2 of 2 Posts
