1 - 8 of 8 Posts
ZD30 Out - L77 In!
Hi guitarist,
Well done!
I have one of these units and have a licenced copy of Ozi CE, but didn't think of installing it onto the GPS Navigator.
How did you go about installing it? Did you have to install using Active sync or just copy the Ozi files onto the SD card?
Cheers,
I've got one of these as well and it works a treat. As for "installing" it all you do is copy the ozi ce onto the flash card and then browse to the exe using the gps config/exe path. It really is that easy...
Hmm I have the old one and its great... maybe its time for an upgrade.
In a GU, I've screwed the screen holder to the dash at the right of the steering wheel. This spot is at a great height and it doesn't block and view of the road.
i have a dash pod wich i built and has the gps velcroed to it along with my phone, i pod and uhf mic.
yeah just copy ozi files to the sd card and select the directory to ozi, really simple.
there were other ones on ebay for $208 but i bot the one with the faster processor and more ram.
as for the link just ebay "gps touch screen"
i will try get some pics up of the unit on the dash pod.
1 - 8 of 8 Posts
