1 - 1 of 1 Posts
not sure if anyone has seen a similar problem? my '98 GR has a short to earth n/s/f wheel sensor, so say nissan after being plugged in, they also say there is a fault code to indicate the actuator is faulty. i have not got a warning light, and i've not checked it yet but fear it may well have been taken out by a previous owner. sometimes under braking, the abs pump kicks in and violently pull you to the right, as if brakes were not working at all on the near side. i've changed the acutator for a used unit, and it is exactly the same. surely a short to earth on a wheel sensor would shut down the whole abs system? any ideas? dont really want to start throwing money at it with no real idea if it will fix it.
cheers.
si
1 - 1 of 1 Posts
