1 - 5 of 5 Posts
Hey guys it's been a lil while. Still doing some work on project pat. Was talking to a guy with a Nissan medalist . And he was saying that with maybe a lil rework, a RB25 head might work with a P40 block. Can anyone here enlighten me on the possibility
1986 SD33T SWB
I can't see how it could possibly work.
Head bolt pattern is different, I'd bet the bore spacing is different, RB head is SOHC or DOHC, P40 uses pushrods.
The only way I can see that they're close is bore size, RB is only 0.3mm larger.
Any fuel injected head can be used?
1986 SD33T SWB
The standard head will work.
You can place EFI injectors in the throttle body or intake manifold.
1 - 5 of 5 Posts
