mine has gravel sensors aparently, Still no better tho if anything worse as I think it dosent apply brakes to all wheels at the same time just brakes 2 wheels at a time and alternates to prevent going into a slide. correct me if im wrong.Believe the late models have a gravel sensor that helps the ABS deal with non sealed surfaces.
Keep in mind that in modifying / turning ABS off you may well void your insurance in the event of an accident if the assessor were to find the mod......
If this really does bother you, the solution is to (each time you wish to disable the ABS) remove the ABS fuse and replace it with a blown fuse of the same value (7.5a). That way, if you have an accident, you could argue that the fuse must have blown during the course of the accident.Believe the late models have a gravel sensor that helps the ABS deal with non sealed surfaces.
