1 - 1 of 1 Posts
Reading the thread on removing the rear power outlet mad me think about something that may be of some use to someone
When i fitted a UHF to my 2005 GU DX i found that on the DX there is a unused 2 terminal wire harness connector beside the front lighter socket that is normally used on the ST & above grades to power the standard power outlet beside the lighter
If you have a DX all you need to do is put 2 standard male spade connectors into this unused female connector & you have fused power supply that is active when the ignition is in the accessory & on position
Regards Don
1 - 1 of 1 Posts
