Might be a stupid question and i'd imagine it would be easy enough to do but i put a 6 inch lift into my gq and now the diffs hang out on the drivers side. I was planing on just pullin the panhard rods out out and fiddlin with em until theyre right but then had someone tell me not to tamper with them too much and im better off takin it into a shop. How do i go about adjusting them? or am i better off just takin it into a shop?? Cheers
nissan/gq
measure
just measure the difference between the chassi and hub on either side and adjust to suit,
try and do it on flat ground and have another person to help push the body back over to line up the bolt holes, you will have to adjust them again in a month or two when the springs settle down/sag
just adjust it yourself.Measure the distance between the chassis and brake disc ,or rim,if you don't want to take the wheels off to get the rear centralized.and then move it left or right .I think from memory it will need to go to the left more
