Hi guys,
First post here so a big hello to all you Nissan gurus! Here is my situation; I recently bought a Defender 90 which I am building into a competition Trayback. At some point in it's life someone has transplanted an SD33 into it. It's running lovely but I have one problem. The notorious "oil cooler filled with crap" scenario! Unfortunately it had gone so bad that the build-up of crap had started corroding the housing which now has many holes in it. I never noticed any leaks when buying it cos the crap was blocking the holes. Therefore I need a new housing. PROBLEM! Here in Ireland there isn't a trace of parts for SD33 engines. I have tried every scrappie from North to South. So my only options would be to get one from you nice fellas down under and have it shipped up OR...
Laser cut a plate that fits the block where the cooler went (I can do this where I work) with a hole in it for a pipe fitting to attach, then pipe in a seperate oil-water oil cooler between this and the banjo fitting to the head. I would then have to tap the oil filter housing to bring two hydraulic hoses from that onto the new cooler. Or I could ignore the water and use an air cooler.
Have any of you guys done this before successfully? I know you would have no reason too unless you needed better oil cooling. Any help/advice would be much appreciated!
BTW my engine is from an MK with the 5 element cooler...
