hi all
Ive just changed my filters on my 07 3.0l diesel CRD, all was fine , changed air and oil also cleaned MAF sensor, all was good , the next day I proceeded to change the fuel filter, easy to do, so I thought... did a CRC diesel purge, then change the fuel filter ,hoses back on then primed up ready to go, took a few turn to get it going but it started, went for a drive found it a bit lumpy, slight leaked from the water sensor, fixed that, all was good, UNTIL the next day it wouldn't start, so I re tightened all the fuel pipe clamps, changed the primer(as I thought that was the problem) but it still is not great to start and is very lumpy.
I purchased a osaka filter, could this be the problem, should I go genuine??
