1 - 3 of 3 Posts
Just removed my standard TD42 alternator as its over charging and replaced it with one from a RD28, i dont need the vacum pump as i have one on the block.
Problem is i have 3 lights on the dash now Diesel filter, Battery and handbrake that dont go out when ignition is on. ALternator is charging fine and putting out 14.41v etc.
Does anyone know if the 2 wires in the connector are different between the models or can i turn them around without blowing something up.
cant really answer your question but you will prob find a wiring diagram for both 2.8 and 4.2 in the gregory's workshop manual. do you have one? if not let me know and ill look tomoz. are all others wires correct? these are the exact lights that come on when the alternator is not charging. earth disconnected?
going to clean the earth tmrw and run a test light thru the leeds etc, dont have a gregorys have the Nissan manual but it doesnt cover the RD28 only the TD42
1 - 3 of 3 Posts
