Hello
Car is a 2005 GU. Originally ZD3o. TD42 swapped in.
I'm having charging issues. Sent the alt for check and it came back all OK.
Tested the 2 wire plug. I get 12.5 volts on both the yellow/red (sense) and white/green (field) wires.
Issue is, using a test light, I get a very bright light on the sense wire, but a very dim one on the field wire.
Does this sounds OK to you or do you think I have a faulty wire?
If it is a faulty wire, it's just running a new ignition wire? What about the charging light on the cluster?
Any advice willl be greatly appreciated.
