Part 2
Air tank: As I have a wagon I was severely limited on where I could put this. I followed the lead of others in that old thread and put it under the driver's seat on the outside of the chassis rail, it's really the only spot it will fit. I used a 9L aluminium tank (about $250), steel ones were a lot cheaper and next time I would probably go that way.
In the above pic, we are looking towards the front of the vehicle. I had to put the drain valve on the side, not the bottom of the tank, by rotating the whole tank., This was so it didn't get snapped off the first time I ran over a rock or log. To actually make it drain, I used some 2-part epoxy to glue a section of thin copper pipe inside the 1/4" BSP brass nipple the valve is attached to, so it protruded about 6" inside the tank. I tightened the nipple up, marked the bottom, unscrewed it, and bent the pipe down so it would be touching the bottom of the tank when it was fully tightened. Took a few goes but I think it will work.
I had to modify the mounts the tank came with so it would sit flat against the floor pan, to maximise clearance. I removed the driver's seat and carpet, welded the bolts to the mount, used grease on the ends of the bolts to find where the holes needed to be, then drilled and bolted them. I only ended up with one extra hole, too! Bolt holes were sealed up with silicone.
It sits slightly higher than the chassis rail now (only by mm), but it needs a plate or bash guard as it is vulnerable there... as you can see, looking at the sill to the right of the tank.
Attaching the hose: I was able to crimp all of the o-clips onto the hoses in situ, despite the tight access- one disadvantage of this style of hose clamp is that you cannot tighten or loosen the BSP side of the fitting, once the hose is on, without twisting the entire hose. The teflon hose is moderately flexible, too, so I was able to use a 90deg barb off the front of the tank and run the hose inside the front shock mount along the chassis, well out of the way of anything.
What's left: All I have to do now is:
1. Run hose to rear of vehicle and mount Nitto fitting
2. Source a longer drive belt and hope the pulley line up (power steering, compressor, crank)...
3. Wire up the condor to my dash switch.
Incidentally if anyone has any good ideas on how to do the last one, I'm all ears. The instructions that come with the Condor are for 240V and I haven't figured it out yet.
