Hey all, have an arb twin compressor to fit to the Patrol. Was wondering where everyone is mounting them inside the cab, stuck for ideas! Going into a 04 gu Ute.
cheers guys!
cheers guys!
Good point. I’ll run it to the main, still be on a switch. And only want it to run when car is on anyway. Thanks for that!Why to the secondary battery? An air compressor will draw quite a lot of current, and most auxiliary batteries aren't designed to cope with the fast discharge. I'd wire it to the main battery, and only use it when the engine is running. You could even wire it so it can't run without the engine running.
Where abouts did you get the Bluetooth pressure module from ? And Is it going into a wagon or Ute mate ? Looks mint either way, have to post some photos when it’s complete!I've mounted mine to the panel next to my fridge/drawers. I also bought the buetooth pressure control module and remote mounted it next to the compressor due to space constrictions with mounting it on the compressor. It will be plumbed into a quick connect on the rear drawer side panel. I haven't had a chance to finish the install yet, but will get it sorted over the next couple of weeks hopefully.
