1 - 7 of 7 Posts
Nissan Patrol
I have an 07 auto and the gear shifter button will not release once started, have to use shift lock release button. Moves ok once this is done until you turn off vehicle and you need to repeat sequence, shifts in neutral ok on accessory but wont shift in start mode.
Has anyone come across this before or know what needs to be done or procedure to fix.
Have a look & see if your brake lights work because you have probably blown the brake light fuse
Have you been towing lately because the most common cause of a brake light fuse blowing is a trailer with dodgey wiring
Regards Don
1 - 7 of 7 Posts
