Mates planning on doing this in his 05 GU4 3l.
I've herd that you need to cut the transmission tunnel to do this? Sounds odd to me i've done them before on other cars and its usually just a case of swapping all the plates/adapters over from a donor manual car. Can anyone Confirm this?
Will the cars ecu have any problems with the auto removed and a manual in place? Might thru up an AT light on the dash but i'll just remove the globe. Anything else?
Anything else to consider before getting into it? I've got a complete donor vehicle so should have all the parts required.
Note: Anyone wanna buy and 05 Auto Trans 90,000kms. Make an offer.
Cheers.
That's BS about cutting the tunnel. The tunnel's are the same. It's not that hard to convert from Auto to Manual. I went from TB45 auto to manual after i blew the auto from fitting a turbo.
_
absolute madness just spend 100 odd dollars on a lock up kit and its better then any manual
I can see wanting a manual, but wouldn't it be easier to just buy one?
