Hi All, New on this forum and it looks to have a good community.
I have had previous patrols, and have now brought an old one just for alittle bit of fun. Its a 2002 GU model, 3 litre engine with 3 speed auto ( plus Overdrive )
I have a vehicle manual in a CD form for a GR Europe patrol.
However I do have some issues with the automatic transmission.
1. When I put the vehicle auto stick to gear 2, no problem with that, but if I click t up to D it will not change into 3rd, I have to put it into neutral then back in D, then all good into 3rd.
2. The vehicle when in D changes into overdrive, that's OK, BUT it does not matter if the Overdrive button in on of off, it still changes into overdrive. I cannot get it out of overdrive except by hard acceleration ( kickback) or slowing down - then it does come out of O/D, the O/D light on the dash works when pushing O/D button on/off.
The automatic changes well between all gears. I have tried the manual for help, in the testing by changing through the gears - O/D button On / OFF, press accelerater etc, I have not code on the "sport"button just blank.
has anyone had this problem or can head me in the right direction.
Thanks
Thanks
