Hi All,
I have a 1993 Patrol 4.2 Diesel with manual hubs. I would like to know if anyone can tell me the thickness of a new brass thrust bearing. The one that slides up against the cv joint. It only comes in one size and mine is slightly worn. My concern is that with the current thrust bearing and a 2.1mm snap ring (biggest available) I still have @ 1.0mm play between snap ring and manual clutch drive. It should be between 0.0 - 0.2mm max.
Anyone know the actual thickness of a new thrust bearing?
AJ
AJ
