1 - 5 of 5 Posts
Nissan GU
Not sure if this is the right spot for this but, I just ordered one of these if anyone is interested!
We have a Head & filter available , it has 3/8” BSPT ports and it will take the Baldwin B50 filter, your price $135.00 inc gst plus freight . I would need 2 days to get it in.
Regards,
www.westernfilters.com.au
Yes I have one too. I went the OB135 filter head with 1/4" NPT ports to limit oil flow to the filter.
Im taking oil from the pressure sender and returning it via the filler cap.
Has anyone done this in conjunction with a relocation kit? I figure getting rid of the second oil filter is an advantage, and you have the fittings you need for oil feed and return.
http://www.derale.com/
If you go to the website, click on the drop down box up the top left, and then click on Oil Filter Relocation Kit.
You would then only have two filters to deal with at each service.
Thoughts?
Looks good.
What I want to do is different. I want to remove one standard filter and fit an adapter in place. This will be the oil feed and return for the remote filter. This means that you do not have a filter that you do not need.
1 - 5 of 5 Posts
