1 - 3 of 3 Posts
Greetings
My engel sits high up ontop of my rear drawers (which are made of ply have no runnners and slide excellently on candle wax, just thought I'd say that).
The left barn door is the problem as I need to fully open to have enough clearance to slide the fidge out. The fridge can not move over to the right as it just clears the main barn door top body lock.
This worked well for the first few trips but after going out to Blackstone and back the left barn door gets very tight as I am opening it all the way.
I have pulled off the plastic covers sealing the hinge pins and had a brief go at knocking them out to clean and grease them but the pins are a bit tight. Any suggestions.
regards Godders
Not sure but from memory i think the pins are kneeled over so you may need to make new ones. Or somehow grind/drill the top then use a pin punch to hit them through.
Ooooooooooorrr buy some good second hand ones like i did for $30
1 - 3 of 3 Posts
