Thanks guys, what are cable glands? GQ shanyne
This. Keeps the car safe in event of a short or high current issue.Went under the car and came up in the cargo area. Use rubber grommets in the holes you drill to protect cables.
That depends on where you do it. On a flat section with no extra structure there it should be ok. The chassis has lots of holes in it already. Keep away from any structure, such as crossmembers or corners.Is it ok to drill into the chassis?
That's what I did also.I ran a good quality cable through a pre-existing hole in the firewall on the passenger side, near the aircon fan. From there you can run it in the gutter underneath the plastic steps right the way to the rear wheel arch.
