nissan patrol 3lt turbo diesel
Hi guys need some advice/help,
Last week left my lights on for a few hours.. Battery died, got it pushed started.. Then today car wouldn't start again.. So pushed started it again, but volts are very low, headunit turns off when I indicate/high beam.. And everything's slow and dull,
It's a 92 maverick 4.2td
Thanks all
I would suggest charging the battery with a battery charger and then see if holds it charge. The alternator will not bring a flat battery back up to full charge.
as Grant3608 said then check the battery voltage to make sure its all good and hasnt dropped a cell etc. Also test the alternator output voltage with a multi meter with the engine running at around 1200rpm while your at it.
