1 - 2 of 2 Posts
Hi,
I need to pick up power from an ignition power source to switch about 6 relays.
I'm not sure how much a relay draws to activate but figured adding this many to either the wipers or cigarette lighter was a bad idea.
What's a better alternative? Is going direct from the ignition switch the go, if so, could someone give me a quick run down on how to pick up the correct wire? ie at the ignition barrel or is there a other spot?
thanks
Every dog has his day
2005 TD42 GU IV
Normal relays only draw 80-100 milliamps so no prob triggering them from wiper motor or similar mate.
Reactions: 2bukoo
1 - 2 of 2 Posts
