1 - 5 of 5 Posts
Looking to upgrade rotors and pads on the old bus. 2000 ZD30. Have had slotted RDA before with good results BUT.... having moved to the top of the Great Dividing Range in Armidale, any time we travel back coastal for camping with 1.5t camper in tow we need to go 'down the hill" with steep descents for about 10-15km.
Having an auto and using 2nd gear with camper in tow still wants to push down hill too much so constantly on/off the brakes where I cooked the old brakes and replaced the pads but the rotors show the heat thats been in them recently.... and need to be replaced.
What would be the best rotor/pad combo for towing a 1.5t braking & heat dispersion?
You need one of these
No Patrol :(
Have you fitted a torque converter lock up switch, should help with engine braking. Back in the 70's we frequently did that road towing similar weight van in an Austin 1800. Never had problems with brakes going down, but always overheated going back home.
As for brakes, quality rotors with EBC Yellow Stuff pads are highly regarded or front pads from 4.8 GU.
· Administrator
Agree.
I have the 4.8 front 'soft' pads against my RDA dimpled and slotted, works bloody great and very little dust, unlike other 'soft' pads.
1 - 5 of 5 Posts
