a guys just a quick question will a big block ford or chevy fit into a mq patrol as i can get cheap big blocks and would love a bigblock in one bt don,t know if anyone has done it or if it will fit any feedback appreciated regards dan (aka smokey)
Both engines are similar in weight as the sd 33 weights 600 plus and the big block Engine Weight FYIedit: you guys were too quick and replied while i was writing this.
@seehuusen, 383 is (typically) only a small block.
you read my mind smokey, im on the shop for a big block chev at the moment. i read some magazines the other day with some dyno sheets and ive seen the light lol.
sounds like you can answer a few general questions for me. ive done a quick google search, seems they have the same gearbox bolt pattern and engine mounts as a small block. so if a small block was in the engine bay, a big block will bolt up in its place? do you know if they share flywheels, i have all new small block chev flywheel and clutch etc here, wonder if they would bolt straight on to a big block.
how much can you get a big block for? i really want one!
to answer your questions, havent heard of one in an MQ. searching google i found a bloke with one in a GQ, but not a lot of info on it. I have heard from a guy round the corner from me thats done many V8 engine conversions on both MQ and GQ that MQ have a lot more room and are easier to fit a big engine into, so thats good news.
MY-TD6i makes valid points about the gearbox and diff strength, however my personal intentions are for a nicely reco big block with all new manifold etc to 'refine' it, but not necessarily make extra power. i reckon the stock parts would hold up okay then.
with regards to the brakes and springs, i wouldnt worry about it. ive heard the SD33 weighs a bit more than a small block, and a big block weighs a bit more than a small block, so its all good imo.
Stop talking about Duramax engines, everytime I buy a Lotto ticket of late it turns into a Duramax in front of my eyes.dry weight of an SD33T is not 600KG plus!!!
It's 305Kg dry and I've had my engine out 3 times in the past 2 years... I guarantee my engine hoist can't lift 600+ kgs LOL
in comparison, a 7.2 liter Duramax V8 diesel weighs 1180lbs or 535Kgs and a TD42 is 352Kgs (someone actually put their engine on a set of scales on outer limits TOP NOTCH!! LOL
X2 BUDDY!!!Sweet sweet diesel power, do want!
