181 - 200 of 334 Posts
Thanks for your technical input into this thread gee..
Seem Pau 's only worry is not looking like a dork..
But it's not helping ..🤭
06 Td42ti coil cab chassis
Discussion Starter #182
stay a dork toy..
it suits you driving a Belmont spec, out the front of the bingo hall grandpa CRuD.
GUII ZD30DI Wgn
I knew I should have used the Turtle Wax polish instead of the ebay stuff on the Big Scoop before I left!!!!! Best eco I could manage on the trip was 10.04L/100k, disappointing :(.
Discussion Starter #189
Turtle wax hybrid ceramic..
Will restore your eco and make your scoop as shiny as the top of idiots noggin.
Do yourself a favor.
Wouldn't you get more dead bugs on the IC and blocking it's airflow???
Just putting it out there....
I must admit I have had a fair few small rocks through the scoop and onto the intercooler, also an unfortunate small feathered flying thing got scooped. Insects seem to be light enough that they are deflected by air movement up and over the scoop.
Discussion Starter #192
I spray surface spray around the lips of my de-dorked scoop..works a treat. ;)
Discussion Starter #193
Are you sure your thermo fans are running the right way troy???
Maybe there not and they are sucking buggs through your dork scoop.
Discussion Starter #194
or fit yours like Neardood1 if you suffer from Entomophobia.
GUII ZD30DI Wgn
No. Just putting a fact out there :).
Not to mention wind drag co-efficiency
It would be as efficient as a Mini Cooper S
My Mini was very efficient, under 2L sports sedan lap record holder at Amaroo for 5 years :).
Interestingly 50million butterflies and moths gave their lives for this trip, The windscreen was covered in splat of all colours at one stage and I saw many that appeared to be swallowed by the scoop but at the end of the day when I raised the bonnet to investigate it was no worse than with the original which impressed me, a bird would be a totally different scenario, sadly I had a bird fly into the top of the windscreen, whereas you could see the butterflies/moths deflect near the top.
As some may know I posted a wool test video I made many years ago when people were saying the original scoop didn't do anything, the vid proved them wrong and I had a fishing rod holder, bonnet protector that sat above bonnet line.
Discussion Starter #196
And gee, don't forget to tell them about all the chickie babes that were waving and flashing their lights and (.)(.) At you because of your sexy new scoop.😉
GUII ZD30DI Wgn
