101 - 120 of 185 Posts
GUII ZD30DI Wgn
Turn up yet?
Nope still waiting, waiting, waiting.... but my 3 new security sensor lights turned up, Troy can't sneak up on me now.
06 Td42ti cab chassis
Discussion Starter #102
You should know by now gee..Germs have no borders and cant be seen.
just a good guy.
2009 gu ute
Went for a blast up the freeway in the ute with new big mouth scoop, must say temps where down going up the hill to what they used to be. Thanks to whoever posted the eBay site for them much appreciated.
Reactions: Marko_SJ
Discussion Starter #104
Well done Nick..
Another happy De-Dorker..
1986 SD33T SWB
Online I found a simple/cheap temperature readout system that I can connect to the IC exit and have a digital readout double sided taped inconspicuously to the dash.
Where did you get it from?
I'd be interested in getting one, using it once, then desperately trying to forget the post turbo temps that i see and then worrying about about my engine going into meltdown any time I go up a slight grade.
GUII ZD30DI Wgn
Found one here:
1986 SD33T SWB
GUII ZD30DI Wgn
523411
It's here at last..................
523418
523419
523420
Pity the Trol will be off the road for a few weeks for Covid Projects.
Discussion Starter #109
It's a polarizer..:oops:
Discussion Starter #110
So no results for a few weeks?
GUII ZD30DI Wgn
Discussion Starter #112
you shouldnt talk about throwing things to the other side of the room in front of troy Ross.. I know your not REMOTEly trying to upset him, but it's Still a bit of a sore point with him.
GUII ZD30DI Wgn
I don't like to the look of the gauge face when it's turned on.. couldn't you of found a better looking one!
Not for the price I got this for, really only a one off use, I calibrate it in boiling water and stick it under the dash out of main view, I hate digital gauges.
It's no good for you anyway, you only have a little one :rolleyes:.
Go The Knights and Blues
There's a old saying Ross.
" Size doesn't matter, it's the way you use it that does"...
Discussion Starter #116
a dork
GUII ZD30DI Wgn
Yes Troy, especially for me.
Jury rigged. Spot on for ambient.
523424
Discussion Starter #118
well its been a few weeks..Is it hooked up yet Ross?
GUII ZD30DI Wgn
Discussion Starter #120
Do you run a fan under your intercooler Ross?
