1 - 20 of 25 Posts
There is a few chev v8 diesel conversions around and I have one myself. I was just curious if there is any other similar conversions out there, like cummins diesel or perhaps nissan truck engines into patrol?
they already have a nissan truck engine. :)
the problem is the sheer weight of big diesels. You're looking at half a ton or more.
Someone once told me a chevy v8 diesel weigh's around the same as a td/tb 42?
I don't know about the 6.5 chevs, but the Duramax weighs in at roughly 380kg which is about the same as a td42 as far as I'm aware.
I was talking about cummins when I said half a ton.
theres a few duramaxes about. youre looking at a lot of coin.
Cummings make a 4 cylinder at 3.9/4l 100kw/350tq stock this would be great.
It's the same as there 5.7/5.9 block just minus 2 cylinders so gear boxes/accesirirs fit right on
SUI GENERIS UTE
GQ Ute 1990 Silvertop
Or maybe a Steyr seems to be the flavour of the year for the military now days.
Bore/Stroke: 85/94
Cylinders: 6
Displacement: 3.2
Max Output: 200kW/272Hp
Max RPM: 4000
Dry Weight: 290 kg
Is there anything about 5 litres with direct injection and 4 valves per cylinder apart from the Audi V10?
nissan safari
im in the process of fitting a NISSAN FE6TA
445kg dry
6925cc 108mm Bore 126mm Stroke
235HP/173KW @ 2800RPM
and the best bit 647NM @ 1400RPM and over 520NM at 900RPM
keeping the STD Nissan box gives me a built in equivalent of dual transfers
should be fun!
445kg dry
should be fun!
i want photos, ive thought heaps about doing the same thing, big diesel, all nissan, sure it might not be a fire breathing duramax but its got all the right badges on it!! How far along with the conversion are you??
445kg dry
should be fun!
Cool, any pics yet?
nissan safari
the project has only just started so new in fact that I only picked up the motor last week the chassie was just organized today & the 2 bodys that will be cut to make a mid wheel base sitting on a LWB chassie with the ends cut off by 100mm front & 180mm rear to push the front & rear over hang to nearly nil
so far all i have done is made up mounts for the front of the chassie/body +65mm iv also cut the front off a wreck to wield on & extend the bonnet 140mm so i can fit it all in. have started the mounts for the gear linkages to sit on the chassie so i can run the remote shifter for the 6SPD & started looking at how to put a safari transfer case on the back of the box
also just organized for a mount strap to be bent up for me out of 200mm wide 1/2" plate to sit under the sump come back up across the top of the chassie & wrap around the sides to be wielded on & use the factory Nissan MKB210 mounts in the front i will then fab up some heave duty mounts for the rear using the factory mount peaces along with 3/8" plate.
currently the plan is for 40" trepdors & 4.1:1 ratio diffs
the rear diff is a HJ260 model out of a MK patrol with the short side cut off the housing (MKs are off centered) and a long side off another wielded back on in its place to give me a much wider track & full floater axles
im still unsure what to do with the front diff tho, open to suggestions.
douse any one know where in ither NZ or Auzzie i can get good strong axles made to measure? in witch case i would widen a GU front housing with a GQ rear center in it ti give me the bigger spline count etc.
Jeeeeeeeezus, that's a big project! Good luck with it all can't wait to see the finished vehicle.
GQ rear centre wont work well. you'll be driving it in reverse and will go through pinion bearings a lot.
Unless you mean just the very centre and use a GQ front 3rd member and crownwheel and pinion.
nissan safari
take it you mean this for the front?
just mean the carrier so i can run the bigger axles & higher spline count as you can open up the GU CV`s to take 33mm axles instead of 31 if you want and more importantly the higher spline count for strength.
still will be using the H230 (STD GQ/GU front)front 3rd member & CW/pinion
1 - 20 of 25 Posts
