1 - 7 of 7 Posts
2001 TB48 GU Patrol
I have had my egr blocked for 3 or so weeks now and have noticed a oily residue around where i blocked it. I used a peice of 1.6mm stainless. Its blocked it at the top pipe into the manifold. would 1.6mm be too thing and not seal properly? maybe i will block it at exhaust manifold also
ZD30 Out - L77 In!
Hi Jay,
If you have fitted a blocking plate that is thicker than the original gasket, you may develop an oil leak because the pipe flange won’t sit flat on the manifold. You will need to loosen off the bottom 2 bolts at the EGR valve itself where the alloy pipe comes from. Also, I’d put a light smear of oil tolerant silicon on the blocking plate and tighten the top 2 bolts first, then the bottom ones. This is how I stopped mine from leaking.
2001 TB48 GU Patrol
i thought aluminum blocking plates could disintegrate and destroy the engine:S
builder not a buyer!
I blocked my egr at the bottom pipe that comes around from the other side of the engine. Hope this is ok? Used 1.6mm stainless too but haven't seen any oil residue yet. Thanks for the heads u
I'll keep an eye open for it
nissan patrol gu
Hi Jay,
X2
I removed the feeder pipe from the valve to the manifold and made two plates to replace the gaskets, from .9 316 stainless..... and as Chaz says a smear of oil resist silicon, but not RTV 732 or one containing Acidic Acid as it will 'eat' aluminium, over time.
My 2 bobs worth
1 - 7 of 7 Posts
