21 - 24 of 24 Posts
Did u clean out IC prior to isolation of CC vent return back thru into pre turbo induction duct (Fabwitz intake pipe)?
How is cooler looking inside (hot and cold side silicons)?
Are U suss on turbo?
Maybe do 5000ks and check qty in bottle and oil use. No positive pressure from CC venting having impact as return vent hose is isolated from induction side of turbo.
Discussion Starter #22
Not sus on anything.
Just want to get to the bottom on my oil leak.
Discussion Starter #24
Ok well an update.
2000 ish k done.
No more oil residue out of the inter cooler piping. The bypassed provent is dry. So I no longer think this is a blow by issue.
The oil line to and from the turbo however, is slick with oil after a week. The area was thoroughly degreased and cleaned. I have a new one and some new gaskets to install. Just lacking the time. Now I’m starting a new job and will be away for 12 weeks. Hmm.
Really hope this is the problem, maybe I damaged it somehow during install.
Rich
21 - 24 of 24 Posts
