1 - 20 of 37 Posts
Hey all, My L28 is blowing too much smoke.
It never use to blow any smoke and now its seems every time I put my foot down is blows a lot of smoke, worse then a diesel.
It is also using or leaking tons of oil.
I have a spare motor out the back and I keen to re build that some time soon but I don't have the dollars to do that at the moment.
I also know it needs an oil change and once I get back from schoolies that what I will be doing.
But can anyone tell me that there could be an easy explanation for this, that doesn't require a huge amount of moolah.
I love my troll and to see it sick, sucks.
Any help is good help.
Cheers Matt
KICKEN BACK IN THE BUSH
Do a compression test
That will help determine what it could be
I think its time for a few beers for Disco Muzz,and get him back in the shed
yeah as dad said, the smoke is a bluey grey colour!
sorry dunno what i was thinking, should of written blue but wrote black, and its not even friday yet
I did a motor change recently because mine was exactly the same, blowing smoke, using lots of oil and fouling number 4 plug all the time. I got another motor from a forum member and it has been all good since. Had the old motor out and new one in in about 6 hours.
Yeah well I am considering the same. I have a spare motor for the car already, which is actually the original motor. Once I get from schoolies I'll chuck it up on an engine stand and start to rebuild. If we do a good enough job I will chuck up our progress on the forum
Mine smoked a bit too espacialy when full trottle. Ive used 10W40 at that stage and switched to 20W50 GT1 from Kendall wich we use in our BMW's. The smoke was gone and it burns almost no oil anymore!
So, try some thicker oil and maybe some treadment for seals.
The PCV is fed through the carby post-air filter.
Any chance this could be over oiling the intake?
As an update.
Matt went over the sump and rocker cover with a torque wrench and ALL of the bolts were loose (some finger tight).
A new rocker cover gasket was fitted. Hopefully, with the re-tensioned sump pan and this, we should reduce oil usage.
Now for the puffs of blue exhaust smoke!
Just watch running heavier oil
If the oil pump is showing signs of age/wear the heavier oil could wreck the oil pump quicker
L28's are tough as hell. They can run forever. Just try the thicker oil. Not 80W90 but at least 15W40 or what I did: 20W50.
Fair enough!
But first I am going to try venting the PCV valve to atmosphere rather than through the carby.
Suspect old dodgy oil is being vapourised and feeding back through the intake, oiling the plugs.
We shall see!
Is the smoke normally after an extended time of overrun? (long decents?) My old girl puts out a hell of a plume of blue smoke after running against engine then accelerating towards next incline, always put it down to worn valve stem seals, mates SD33 does same with 500+k's, once the blue clears, the black starts! Mine been worse since going to Repco 20W/50, but got 20L of it, so the old girl will have to put up with it for a while.
This is great feed back.
Thanks folks.
I guess we could summarise it that;
A puff of blue smoke is not really the end of a L28.
1 - 20 of 37 Posts
