1 - 15 of 15 Posts
2 " longer then the existing ones - sorry I could not help my self
Reactions: james008
I had to close by browser to stop myself from saying the same thing yesterday. I knew someone would lol. But still holds true id say measure your current bolts and add 2 inches to it.
I think the simplest way is to buy some 1 meter of such pre-bolt (picture) in any build-materials story (for approx 2usd), and then cut for yourself 4-5 bolts. for 4 middle ones I've used 14mm. for front/end 12mm. (sorry I'm from Europe, so measures in mm :)
(of course there is also welding, and cutting metal experience appreciated).
(hardtop model)
Bolts need to be high tensile not mild steel all thread , and this site is Australian based so mm is our unit of measurement , so no sorry needed :)
Sent using carrier pigeon from Bill Lawrie
How about the rear ones? They tread into the body with finer tread. And with the stock bolt you also use a small tube where the bolt goes thru which prevents that you crush the body rubbers.
nissan mk
Hey Shark, have a grave dig I did a post on bolts with all dimensions and a few pics.
Cheers,
Brian
1 - 15 of 15 Posts
