From NCOP11
Raising the height of the vehicle may be performed without certification providing the overall increase in vehicle height is not more than 50mm. This may be achieved as a single modification such as the installation of a 50mm lift kit, or by a combination of smaller lifts as described below:
- the fitting of body blocks or lift kits (50mm maximum if no other modifications resulting in a change of vehicle height are performed);
- suspension modification, (50mm maximum if no other modifications resulting in a change of vehicle height are performed);
- changes to tyre size (maximum change in tyre size diameter of 50mm); or
- a combination of the above that results in a change of vehicle height not exceeding 50mm.
From VicRoads
Vehicle Standards Information 8
Guide to modification for motor vehicles
This information sheet supersedes
all previous copies of VSI 8.
June 2021
Raising of four wheel drive vehicles – alternative to VSB 14 Modification Code LS In the case of raising the height of an off road type 4WD of ADR Category NA, NB1, MC or MD, and only in this case, the following applies as an alternative to meeting the suspension lift requirements of Section LS of VSB 14:
∞ A combination of suspension lift and the fitting of larger diameter tyres that results in a total lift of up to 75mm without the need for the testing and certification normally required by VSB 14 for lifts above
50mm
∞ The vehicle’s suspension may be raised by up to 50mm, provided that sufficient suspension travel in either direction is retained.
∞ Only commercially available suspension kits may be used.
∞ Such kits must be:
- manufactured and supplied by a Corporation;
- specifically designed and tested by the suspension lift kit manufacturer for the make/model/variant of the vehicle being modified to ensure no adverse effect on the modified vehicle’s propensity for rollover, handling characteristics, braking performance and structural integrity when assessed at the combined suspension lift (up to 50mm) and tyre radius increase (up to 25mm), i.e. a total increase in ride height of up to 75mm; and
- fitted in accordance with the kit manufacturer’s instructions, abiding by any conditions or limitations advised by the suspension kit manufacturer and include a written statement (to be retained by the vehicle owner) of the suitability of the suspension lift kit for the make/model/variant of the vehicle being modified whether or not installed in combination with the permissible tyre diameter increase.
∞ Tyres up to 50mm larger in diameter than that specified by the vehicle manufacturer may be fitted to an off-road type 4WD provided:
- The entire tyre cross section is covered by the vehicles bodywork in plan view with the front wheels in the straight ahead position
- The tyres do not foul the bodywork, braking system or any suspension or steering component under any combination of suspension and steering movement.
This is a contradiction in its self, Vicroads say to follow VSB 14 then go and add an other rule that overrides VSB 14. I had this argument with the road worthy inspector on my GU 50mm Suspension lift plus 25mm larger tyre was knocked back because the inspector was following VBS 14 and not the VSI 8 from Vicroads it was a royal pain in the ass.
